stephenspann27
- College Station, Tx
Well fellas I have to take a hiatus from the Jeep world for a bit. My wife and I have plans to start a family soon. It was time to get a larger more modern vehicle. I bought a 2002 Z71 Tahoe love it so far but the XJ will sorely be missed. I plan to get another Jeep soon and trailer it behind the Tahoe. With the little wheeling I've done I've never been that confident because I had no way to get my XJ home should something break.
My XJ is a '87 4.0/AW4 with a DANA 44. It as a "law enforcement" edition so it came with a transcooler. I've owned it for 3 yeras and the first 2 years were spent rebuilding/restoring it. I replaced everything in the motor that showed wear. When was everything but the cam and pistons/rings (it uses no oil). I easily get 21mpg hwy.
The tires are ready for replacing, and the rear leaf/shackle bushings are starting to groan and creak. It also needs a headliner.
The body is in mint condition, no dents. It also has a JVC head unit, and polk speakers
p { margin-bottom: 0.08in; } List of replaced parts:
Suspension/Chassis:
Door weather stripping
Brake pads
YJ front brake hoses
Monroe Shocks
Master cylinder
Tinted Windows
Engine Related:
Goodyear Gator back belt
Murray Water pump
Alternator
Starter
Battery (2 weeks old)
Power steering pressure hose
Oil pump
Main bearings
Rod bearings
Complete head
Timing set
All gaskets and seals
Fuel/Sensor related:
Mustang orange top 19lb injectors
CPS sensor
Throttle Position sensor
Oxygen sensor
Idle Stepper Motor (IAC valve)
I'm thinking about asking $2,100? Is that a fair price?
Suspension/Chassis:
Brake pads
Monroe Shocks
Master cylinder
Tinted Windows
Engine Related:
Murray Water pump
Alternator
Starter
Oil pump
Main bearings
Rod bearings
Complete head
Timing set
CPS sensor
Oxygen sensor
