I have a 93 xj country 4.0L HO with auto trans. Not sure what trans or transfer case I have. I cannot get 4 low to engage. I bought the Jeep a few months back and it worked then but gave a grinding noise when engaging (like changing gears without using the clutch). I was wondering if there is a linkage that needs to be adjusted or did I loose 4 low all together? Not sure if this helps but I have 4 part time, 4 full time, and 4 low as selections other than 2 hi. All selections work great except 4 low.
Also, I am interested in knowing how to figure out what axles, trans and T case I have on the rig. Ehverything is stock on this vehicle as well.
Thanks for your help,
Paul
Paul
