hello, I'm finally making some headway on my wifes project, and although I've built tons of cars, I'm still sort of new to jeeps, so I was looking for what anyone thought was the weak link in this.
90 xj,
-4.7 stroker, MS, probably a 75 dry nitrous shot, cammed for the low end
-ax-15 freshly rebuilt, stock clutch
-np231 with wide chain swap and 6 pinion planetary and JB sye
-front hp d30 w/o vac disconnect, wj knuckles, brakes, stub shafts, hubs for 5on5 lug, high steer
-rear 8.25 29 spline, wj rear brakes, 5on5 lug, moser axles
-RC 6.5 inch short arm kit, prothane bumps
-33" tires, nothing very aggressive tread wise.
-For the Drive shafts, I'd like to stick with factory shafts pulled from something else, but if they start blowing up I'll go aftermarket.
-I still haven't settled on a ring and pinion ratio yet, probably 3.55 or 3.73, we aren't very interested in rock crawling, and although not a highway cruiser, I'd swap in a 4:1 before I'd sacrafice mileage anymore.
-Down the road, it will probably get a hydro boost, and if she really likes the jeep after all this airlockers front and rear and a 2lo kit and long arms for the front, probably better shocks.
-for the frame, I was going to get a full set of stiffners, better bumpers to tie the frame in better, replace the rockers and connect them to the frame rails, some steering bracing, and beef up the shock mounts, I wasn't planning on getting serious enough for a cage.
basically my idea with this has been to maximize the number of stock parts used so that replacements are cheap and plentiful, I hate having a one off part break and being stuck buying another for too much $$$, or worse having to convert to something else because the needed part is no longer made/available (my chevelle needed a new spindle after a disc conversion, and I found out it was a custom part, I had to toss the entire front end because they didn't support their original suspension design). I was also looking to keep the vehicle somewhat tame so that my wife can still reasonably drive it around, after all it is her project.
My question is what is the weak links in all this are, or better yet what you guys think the first couple of things to break will be? Not just wheeling it, but driving it in general. I already have most of the major parts, I'm fairly committed to the engine trans and axles, I'd just like to build the details as right as possible the first time so I don't break anything more than I have too and avoid getting stranded as much as possible.
Thanks for any replies, I've done a good bit of searching, and Ive found info in the individual parts and building them up, but I have had a hard time nailing down where the weak link would be because most of the builds I've found good documentation on are much more aggressive.
90 xj,
