I thought F.T. stopped using heims and are using some other encapsulated ball rod end....
As to the laws there is an ASS full rules and regulations which one can be written for... ANY modification is illegal... do they enforce them... 99.9% of the time nope... they are dumbass laws left over from the 50s & 60s.
I've ran heims on my lower control arms since 97... I like greasable ones... Aurora or FK... as mentioned there are cheap ones & quality ones. I get about 3 yrs. out of them, then they start to get noisy... a shot of grease and they quiet down for a little while...
Curt
F.T. used them for many many years all the up till at least last year. They do use one end with a orbital eye ball type on thier lowers and uppers, and the Trackbar has Heims.
Show me where it spells out no heim or any dirivitive of such?? Its not written anywhere. Niether is vertually ANY suspension geometry or manufacture allowed specs.
Ever go down and try to get car that is piece mealed, registered? They follow the only real specs, DOT standard lights, glass, frame hieght, headlight placment, safety restraints if in production year or new assembly, and only a few others.
FYI for the longest lasting and best quality for our type use. Use a NON-liner, Non greasable style high quality heim. Reasons. Liners distort and thin out and then get spit out and you get that extra space between the ball and race = clicking and excessive wear, Greasable are machined a few different ways, and both remove some material either for a grease channel, or slight irregular shape, either to allow for grease to actually leave a film. Both = quicker wear and more chance at noise and need for replacment sooner. WHen you fill it with grease your only adding a grease film to that excessive tolerance it has obtained and is not fixxing anything.
Run a quality heim, LARGER then you need and after every water, sand or mud trip, spray them out with alot of brake and parts cleaner, drive it some then use a good silicone spray on them and drench them. you should see a good amount of use before you notice any noise. I have beat the hell outa mine and am going on about 3 yrs now on the lower control arms, and 2 yrs on the track bar. Oh and as I mentioned and CAL, use a saftey washer on any single shear location just for piece of mind...
