vetteboy
- morganville, nj
If anything, it removes restriction. Restriction causes heat buildup.
Drilling it out too much will flow like a son of a bitch but can cause your pump to cavitate as the input side won't be able to keep up. This is not good for the longevity of the pump.
With a PSC external reservoir and some pretty big ID hose, I was able to open mine up to about 3/16" with no problems (the stock opening is 1/8"). I tried 1/4" and it cavitated pretty bad.
Steering is one of those things where you don't realize how much better it can be until you spend some money on it. The homebrew stuff is good but will only get you so far.
