I have tried my best to figure this one out but to no avail. Here is the situation;hoping that someone can help.
the headlights on my 93 xj 4.0. keep cutting out and in after about 15-20 minutes of use. This happens during any driving condition when they have been on this long. I have replaced the headlight switch and also replaced the headlight relay under the drivers side dash. Everything is stock with no high output lamps or anything. I thought at first that they might be burning out. this has not solved the problem. Has anyone had a situation like this and successfully fixed it?
I was thinking that there may be a situation where the switch may be overheating because it happens about the same time everytime.
I thought it may be a loose ground but havent found one yet.
I am running out of ideas. Thanks guys!
