I have to agree with a few squirts of some kind of lube in each spark plug hole from an old school squirtcan but from there; crank over with plugs removed til pressure shows up on gauge; put plugs back in and see if itll fire up; itll smoke like Hell til what you sprayed in the cylinders burns out but wait on oil change til the engine has had a chance to warm up; oil dont go bad sitting in a can on the shelf and shouldnt in teh pan either; and warm oil drains easier and you may take some old deposits left over with the draining, tht will be left behind if you drain it dead cold. Once you have it running and warm THEN change oil. make sure all fluids are up to full of course before firing it up!
