Dr. Dyno
- Al Ain, UAE
On the same engine ethanol will not make more power since the energy per volume of ethanol is 34% lower than gasoline. If you build a high compression around ethanol then yes. But it would have to be higher than 10:1.. 14:1 to 16:1 would be better. You can run much higher compression. But you still have lousy mileage.
Yeah you're right about the potentially poorer fuel mileage with ethanol, but it does have a much higher octane rating than gasoline so you can run a higher compression ratio (or higher boost on boosted applications) without spark knock.
While you get less BTU per volume of ethanol than you do from gasoline, ethanol burns with greater thermodynamic efficiency so less of its energy is converted to heat and the engine runs cooler.
