selarep
- Central CA
http://www.harborfreightusa.com/usa/tabviewer/webDisplayItem.do?itemnumber=94056
What do you guys think??? It's only $100 and its flux so I dont need gas. I'm thinking about getting it and doing my bumpers and stuff. would it be good for the job?
I did welding in the Navy as a fire fighter but that was with Miller welders that were as big as a 60" big screen projection TV.
There's also a Dual Mig welder for $130
<< BACKItem Detail for SKU # 94056
90 AMP FLUX WIRE WELDER
Specifically designed to use self-shielding flux-cored welding wire, eliminating any need for gas and regulators normal MIG welders require. Includes: 4'' spool of flux-core wire and spare 0.035'' welding tip.
- Self regulating feed control
- Thermal protection with warning light
- Carry handle on lid
- Input: 115 volt, 15 amps, single phase
- Welding current (2 settings) 63 to 68 amps (low), 79 to 90 amps (high)
- Duty cycle: 10% @ 80 amps, 18% @ 60 amps
- Wire capacity: 0.035'' or 0.030''
Shipping weight: 34-1/2 lbs. function resize(){var maxw = 200;var maxh = 300;var theImage = new Image();theImage.src = 'http://www.harborfreight.com/cpi/photos/94000-94099/94056.gif';document.images['myimg'].src = theImage.src;//var width = document.images['myimg'].width ;//var height = document.images['myimg'].height ;var width = theImage.width ;var height = theImage.height ;//alert("height:"+height+" "+"width:"+width);if(width > maxw && height > maxh){ //alert("1width and height are greater"); document.images['myimg'].width = maxw;}else{ //alert("2width and height are not greater"); if(width > maxw){ //alert("2width is greater"); document.images['myimg'].width = maxw; } else if(height > maxh){ //alert("height is greater"); document.images['myimg'].height = maxh; }}}
[FONT=verdana,geneva,arial,helvetica]View more Chicago Electric Welding Systems items[/FONT]
[FONT=arial, sans-serif]DUAL MIG WELDER 151[/FONT]
[FONT=arial, sans-serif][/FONT]
[FONT=arial, sans-serif]For use with or without gas. Comes with welding torch, tip, grounding cord with clamp, brush/hammer, hand held welding mask and manual.
[/FONT][FONT=arial, sans-serif]Factory reconditioned, factory perfect; Input: 230V, 60 Hz, single phase; Welding current range: 30-120 amps; Duty cycle: 15% @ 115 amps; Draws 15 amps @ 230V; Max. open circuit voltage: 36V; Weldable wires: .023", .030", and .035 steel or stainless steel; .030" and .035" aluminum; .030" flux core[/FONT]
[FONT=arial, sans-serif]ITEM 55250-3VGA
$159.99 $129.99 [/FONT]
