if I was closer Id give you a hand, I just did mine. Its not that bad. put the jeep in reverse while cutting and drilling, NOT tapping, and it will help you cut the shaft square. and I used the edge of a grinding wheel to kind of cup the center of the shaft alittle so when I drilled the hole it bit found the center easily. other then that just follow the directions and you should do fine.
