- MilkyWay Galaxy
Disconect the O2 sensor. Does the idle still wander?
If Yes= then it is not the closed loop or O2 sensor problem. Perhaps a bad Injector connector. I have had that problem with 2 connectors.
No= Check the Air Intake temp sensor, I had one cause wander and a high idle as it failed. Liked to never figured that one out. Also I connected the O2 sensor connector backwards once and it caused low idle and wander in the 200-350 rpm range. IIRC connecting the TPS 3 prong connector backwards does that too. My connectors had broken plastic and it is possible to connect them backwards.
