SOUTHTEXASXJ
- Odem Texas
Just wanted to post up my new steering JCR/JKS/parts.
Huh?DrMoab said:Yeah, wait till you are cruising down a canyon and that ugly dead spot shows up and puts you in a ditch.
At least you will never break it.
That style of steering has an inherent dead spot. JCR tries to fix it by putting in some little donut spacer things but its a temp fix at best.crazyjim said:Huh?
DrMoab said:That style of steering has an inherent dead spot. JCR tries to fix it by putting in some little donut spacer things but its a temp fix at best.
Wait awhile.SOUTHTEXASXJ said:well its sure drives alot better and is hella safer!!!
Just OTK style in general or what? I don't get where this is coming from...DrMoab said:Wait awhile.
Seriously, I wasn't knocking it. I ran the same style for a long time. Hella strong. It will develop a dead spot...and then it will not be so safe.
crazyjim said:Just OTK style in general or what? I don't get where this is coming from...
Yeah, what he said...exactly.Andy in Pa. said:That design of steering has an inherent design flaw that creates a "dead spot" when it tries to twist the TRE on the draglink, where it mounts to the tie rod (this in-turn, twists the tie rod on the TRE's at the knuckles) when turning. SOME of this twist can be alleviated if the TRE on the draglink is mounted on top of the tie rod (this can bring on steering binding problems when flexing), or if it is at 45* between being in the front or on top of the tie rod.
It may start out tight, but it will eventually loosen up and have that dead spot. That being said, I ran a setup like this for a long time. It was bulletproof steering, I couldn't bend/break it (after MANY encounters with rocks), but I had to live with that dead spot.
I never wore them out. I even had one that lost a dust boot(from the twisting) and it never got loose.IntrepidXJ said:the constant twisting of the tie rod will also kill the TREs quicker
Gravesdiggerxj said:don't worry about it... Ryan is just a whiner.... smirk
Sure you'll get a dead spot... but it won't have anymore dead spot than that POS stock steering...
just keep your eye on things and you'll be fine.
looks good! got your trackbar and draglink parrallel and close to the same length: looks setup right to me
