How does this way of doing it compare?
http://youtube.com/watch?v=uTf45ulIyEc
Chris @ GATR said:How do you plan to fine tune the HHO intake? increase/decrease the water level.
You do realize that when HHO combusts, it turns back into water? Duh
I hope you have stainless steel valves or your heads will rust terribly.how would stainless valves prevent my head from rusting?
SeansBlueXJ said:did you do anything to compensate for the O2 sensors?
Chris @ GATR said:Do you say that because your tailpipe drips water every once in a while?
DirtyMJ said:Did you take highschool chemistry?
I did. I hated it. My teacher tried to throw me out on sexual harassment charges.
Anyways, let's just take a simplified hydrocarbon combustion equation to prove how burning a hydrocarbon produces water...
C3H8 + 5(02) ---> 3(CO2) + 4(H20)
That's propane being burned in an environment free of contaminants. I know propane is not gasoline, but I'm much too lazy to look up what a gasoline molecule is. But it is a hyrdrocarbon none the less - they're the same thing with different distributions of hydrogen and carbon.
The water produced will almost always be vapour as a result of the amount of energy released by the chemical reaction. But, sometimes it will condense in the exhaust, and drop out. A dripping tailpipe is that. Yay.
So, it won't rust your engine. At least not anymore than anything else you burn in it.
Away from the sidetrack.
Gojeep said:Funny, as I ran water injection on my V8 for 10 years and 100,000 kms and never had any of the problems you mention. It was the cleanest engine and you would never know it had done that sort of mileage.
GSequoia said:Really the only parts that I'd think might have an accelerated rust issue would be the exhaust system (assuming it's just your standard crappy galvanized). In an old V-8 I'd say that the intake manifold would be at risk too only because of the potential for water to collect in there when you shut it off when cold (so the engine isn't hot enough to burn the water off, I'm really talking about the simple moving your vehicle up a car length).
goodburbon said:Other than those 2 problems the car runs well and gets from 25 mpg city to 31 mpg Highway. Average mpg is around 27.5, the car has never gotten over 31 mpg and never gotten under 25 mpg.
goodburbon said:210.8 miles traveled 8.919 gallons added to fill tank
23.63 mpg.
cal said:I was having a shitty morning. You just made my day.
