ChicksDigWagons
- Upper Michigan
You're not going to find many turbos that are completely sealed. There is/was one company I know of manufacturing them, and that was primarily for small turbos.
Any turbo you're going to want to use at a reasonable price is going to need both an oil and coolant feed/return. I'd personally stay away from non-water cooled turbos as their life expectancy and functional condition ranges are worse.
You can easily get great spool out of a single turbo, its no more difficult than with twin turbos but you have to make sure you match the turbo to the engine, and consequently, run the appropriate amount of boost. Generally, two smaller turbos with an equal flow capacity as a larger turbo aren't going to spool significantly faster anyhow. Yes the rotating mass is lower, but your input energy will be half. No free lunch in thermodynamics. You'll see a larger benefit in spool time in going to a ceramic ball bearing turbo over a sleeve bearing. But again, thats lots more $$$.
If you went with an appropriately sized turbo (I'd take a wild guess at a light trim Garrett T4 without actually running the numbers), you could easily see full spool at 1000rpm or less, and with the redline you'd have with a 4.0 you shouldn't have a problem running out of steam on the top end at 5 or 6 psi of boost.
A two stage sequential turbo setup brings in an entirely new host of problems as well. Turbo crossover can be tricky. Peoples first thoughts are to just run the small one into the big one or vice versa. This has problems because you're always going to be limited by the flow of the smaller turbo. Also, you run risk of overspinning the small turbo. Running them completely in parallel is counterproductive because in the low end the small turbo has leverage over the big one, slowing its spool, at the same time, on the top end the big turbo is easily overruning the smaller turbo. You lose efficiency. Some cars have sucessfully, with computerized gizmos, gotten this setup to work. But many of them suffer problems with power loss at the crossover, reliability problems because of complexity. Anybody who tunes one of these cars typically swaps to a single turbo setup.
BTW, I run a custom turbo'd Subaru. Jeeps are only half my addiction.
-Brad
-Brad
