supertubesocks
- Brea
Welding finished on the little ole Dana 30
I agree it is to far from the mount without support.I thought it would be beefy enough, oh well, I'll just plate it up a bit.
The bar is just tacked so I can set the adjust after I cycle everything.
Thanks but the block didn't survive so I found a rebuildable short block.
If you plate it you can add a double shear from the bottom to the outer platting you do like a gusset.
Looks great, I especially like the trans cooler fan shroud. I'm adding a Deraille now. Where are you going to put it? I was thinking, for me, to attach it to the hood, under the hood with the fan sucking through the engine compartment and blowing out the vents. If room is limited I'd cowl it or locate a fiberglass after market one that would allow the space needed.
I got the track bar location nailed down.
PLEASE tell me there's going to be some gussets and reinforcements on that bracket?
What kind of glass is that up front?
Looks good man :thumbsup:
