- Westminster, SoCal
4:88's will be good with 33's and also with 35's but there's a strength issue because the pinion gets really tiny at that ratio. I would suggest 4:56 and if you eventually go up to 35's then a low range kit in the transfer case.
Ugh..... the pinion is not that small and there is no strength issue. Only few cases I heard of a shreaded pinion that I heard of turned out to be bad gear setup.
I've ran 4.88's forever on my XJ. I had it with 31's (short time as I was waiting for 33's to come in) and it wasn't to obad (top speed about 60~65 cause of RPM's). Then I had 4.88's with 33's which was a blast. Then I went to 4.88's and 35's and it wasn't too bad but I needed something inbetween which made me end up with 4:1.
