I've got an 89 xj, 4.0, manual tranny. I bought it from the original owner. It had a small "oil leak". I did the valve cover when I did some pcv lines. I parked it in the driveway with a drip pan under it. Turns out my "oil leak" is actually gear lube and a coolant leak. The spots land in the same area, in front of the tranny. My tranny is COVERD in gear oil. Being an xj newbie, my question is where would I start totrack this down. Also, where would that coolant be coming from on the back of the motor. My motor oil is not milky, so I don't think its a head gasket issue. Well, not internally anyway. Thanks so much for the help! Jeff.
ps, If anyone is in the Tucson area and has any ideas you can call me on my cell also. 661-3264
