I suggested to a member to relocate his cat further downstream as anfix for heat soak issues. I never once said to "gut" the cats and leave them installed.
Anyway, I recieved an infraction for a post I clearly never made.
How do I clear this up? And why can some forum moderator do and say what they please, even when it's clearly not the truth?
A little reading into the thread, a person would clearly see I suggest catalytic convertor REPLACEMENT and NEVER ONCE SAID ANYTHING ABOUT "GUTTING" a cat!
Crazy.
MT Mike said:Dear 96XJ_4.0,
You have received an infraction at Forums -::- North American XJ Association.
Reason: Advocating illegal 'wheeling.
You are receiving this infraction for advocating removal of federally mandated emissions items (catalytic converter). Even if the cat is left in place, and hollowed out (as you seem to suggest) that is still illegal. We (4wd enthusiasts) have enough issues with the environmentalists without our members and users openly posting about breaking federal law. I suggest that you bring your vehicles back to legality, and that you stop publicly posting about performing such modifications.
I will be editing or deleting your posts. If this occurs again in the future, harsher penalties, such as temporary loss of posting privileges could ensue.
Thank you for your cooperation.
This infraction is worth 1 point(s) and may result in restricted access until it expires. Serious infractions will never expire.
Original Post:
https://driven2services.com/staging/naxja/xf/index.php?posts/244849480/
Personally, cut the cats, get a normal style pre 2000 cat setup for an OBD2 4.0 and call it solved.
I read about this all to much on what should be the MOST reliable xjs!
Right? The last shoulda been the BEST!!!!????????
All the best,
Crazy.
