Muad'Dib
- Bend, Oregon
where is it leaking again? between the fuel rail and the fuel pressure regulator? did you replace just the o-rings or replace the whole quick disconnect?
i would try smearing rtv or some typ of sealant that is resistent to gas around the connection. may look ugly, but it might stop the leak. i know it doesnt sound like a great repair, but it seems like you have change the o-ring and/or connection, the only other option would be to replace the fuel rail as it could be bent or scored allowing the leak.
No its leaking on the Input side of the rail. Or at least i always thought the side closest to the Firewall was the input side (Opposite the Regulator) 1990 RENIX. Before, i was just replacing the orings, but this last time i shelled out the 24 bucks for the darn quick-disconnect kit that has the two orings, the spacer and the clip.
Wouldnt a score in the rail, or on the fitting present itself at all times and not just when its cold?
I really feel like the gas is feezing up the oring a bit, causing the leak until it heats up enough to make a seal again. Like i said it only happened when it was really cold outside. It has not been a problem lately. Its been about 35-50 degrees during work hours when the Jeep is parked outside.
Any suggestions on insulation options?
