justright92xj
- Nashville, TN
I happen to be a chrysler technician, so here is a TSB copied and pasted straight from Chrysler
NO: 18-12-92
SUBJECT: Long Crank Times And/Or Engine Die Immediately After Start Up
DATE: Jul. 27, 1992
THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 4.0 LITER ENGINE.
SYMPTOM/CONDITION:
Vehicle will exhibit long crank times and/or the engine will die out immediately after starting. This condition could be misdiagnosed as a fuel injector or fuel rail problem, but may be caused by a loss of fuel pressure at the sending unit supply hose.
DIAGNOSIS:
Verify that the vehicle has not been started for at least five minutes. Start the vehicle. Vehicles that have a long crank time or die-out immediately after starting should have the following procedure performed.
PARTS REQUIRED:
Quantity
Description
Part No.
1 Fuel Pump Outlet Hose Package
4713610
Consisting Of:
1 Fuel Outlet Hose
4713611
2 Clamps
4713612
1 0-Ring
53000575
1 Instruction Sheet
K6855030
REPAIR PROCEDURE:
This bulletin involves replacement of the fuel sending unit supply hose.
Remove the fuel pump module as outlined on page 14-4 of the 1991 Engine, Chassis, & Body Service Manual, Publication Number 81-370-1145.
Replace the original supply hose and clamps with the parts from package PN 4713610.
Using a new "O"-ring, install the original pump module as outlined on page 14-4 of the service manual.
Start the vehicle and inspect for fuel leaks.
Turn the vehicle off and allow it to sit for at least five minutes. Start the vehicle to verify that the condition has been corrected. If the vehicle continues to exhibit this condition, refer to page 14-36 (General Diagnosis) of the service manual.
POLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Fuel Pump Outlet Hose Replace
Labor Operation No.
Description
Time
14-50-90-90
MJ, XJ, YJ
1.2 Hrs
Optional Renegade Package Equipped
Labor Operation No.
Description
Time
14-50-01-63
YJ
0.5 Hrs.
FAILURE CODE:
Code Description: 59 Internal Leak
NO: 18-12-92
DATE: Jul. 27, 1992
SYMPTOM/CONDITION:
DIAGNOSIS:
PARTS REQUIRED:
Quantity
Description
Part No.
4713610
Consisting Of:
1 Fuel Outlet Hose
4713611
2 Clamps
4713612
1 0-Ring
53000575
1 Instruction Sheet
K6855030
REPAIR PROCEDURE:
POLICY:
TIME ALLOWANCE:
Labor Operation No.
Description
Time
14-50-90-90
MJ, XJ, YJ
1.2 Hrs
Labor Operation No.
Description
Time
14-50-01-63
YJ
0.5 Hrs.
FAILURE CODE:
