Original_MudButt
- In the eighth dimension
In case you didn't see any of my earlier posts about this.....
'98 4.0 with 97k miles.....
Went to Goatfest and ended up with 35 gallons of rusty/watery gasoline in my RV.
I didn't want to throw away over $120 worth of gas, so I pumped out 5 gallons and ran it through a filter I bought at a boat shop. It was supposed to filter out all the water and any crappolla larger than .005"
I put 15 gallons of gas in the tank of the XJ then added 3 gallons of the filtered gas and a bottle of STP fuel system treatment I had lying around.
Jeep hasn't run right since. Every morning it cranks (what seems like) forever before it finally fires. When it does, it sounds like it's only running on 4-5 cylinders for about a minute and idles like crap.
It just doesn't seem to have the pep it had before and the gas mileage seems a bit lower (though I haven't checked so can't back it up with actual numbers).
Now when the gas light comes on telling me to fill up, whenever I turn left it dies for a 1/2 a second or so and then comes back. It never did that before.
The exhaust smells..... Smells like....Well, like burning rusty water....
So far:
No CEL.
I have been through 3 full tanks of gas (the first one of course had the 3 gallons of bad gas and the STP)..
Twice I have bled off the fuel rail (don't ask why, I really don't have a reason, just hoped it would help).
Every chance I get I flog the heck out of it... (Poor man's tune up).
Up next:
Borrowing a fuel pressure gauge to check the pressure in the morning. Even though I wait a few seconds with the key on before cranking it, it acts like it did when I had a leaky fuel filter.
Going to pump out as much gas as I can from the tank with a hand pump. I know water settles on the bottom, there may still be some water in it. I'm trying to fix this without dropping the tank. I've got an OakieTerry tank skid, so dropping the tank is like a weekend project.
Maybe try some HEET?
Anything else I should try?
Could the bad gas have screwed with the MAP sensor?
How about plugged injectors?
I'm leaning towards plugged fuel regulator and or injectors.
Any help here would be appreciated.
So far:
No CEL.
Up next:
