Prepmech
NAXJA Member #981
- Neoga/Decatur, IL
Broke a rear axle shaft this weekend at winterfest. I was able to drive it back to the trailer on the broken shaft. The carrier bearing on that side was damaged from the loose end of the shaft flopping around in the axle tube. Going to upgrade to alloy shafts. Bronco Graveyard has them for $90, should have put them in to begin with.
The 9" pinion is really low, and definately needs a skid. I put an anodized aluminum daytona pinion support on it only to drag it on the rocks and beat the crap out of it. Looking at the James Duff skid because it is the only one that I've been able to find that protects the pinion, 3rd member, and housing.
The drum brakes have been working fine. Even though I have all of the parts to add discs, I think I'm going to wait a bit. Even after driving through quite a bit of mud and water, they are still pretty clean inside. I'll keep an eye on them and clean them out as needed.
I bent a set of sway bar brackets on the d44 trying to wheel with the sway bar attached. A few hits with a hammer and they are fine now.
The front axle has been great, I love the new steering, brakes, and having locking hubs. The tru-track has been working pretty well so far, but I'm still undecided on how much I like it.
I was driving it as a DD for a few months, and putting quite a few highway miles on it. It handles great at 75mph.
It is extremely stable on the trails. Moments where it feels like it is going to tip are now few and far between. I don't have as many options when it comes to choosing a line. The tires sticking out so far have helped by hitting trees before my body does.
