Uglygreenxj said:The pump itself isn't hard to replace, but you will have to drop the tank to do it. Unplug the pump and remove the lines (make sure to take note which one goes where for reinstallation) There are just four nuts to loosen to drop the tank but you will have to unhook the vent and filler hoses . There is a large ring that holds the pump in place. I just us a flat blade screwdriver and a hammer to loosen it. It will be obvious when you see it. If there isn't much gas in the tank, its pretty easy.
Because of the use of 99 in your sig line,it was reasoned that you had a 99XJ.That is why it is best to describe EXACTLY what year XJ you are working on.XJ_99 said:I have a 91 and it looks like the assembly sits in the front of the tank?
bacelaw said:I have had the same question for years - i have a '96, which is supposed to be the first year for the IN tank pump..
however, mine looks like it is also in the FRONT of the tank..what gives?
