FT: 88 MJ LWB, 6 Cyl, AW4
bigalpha
Moderator
Tucson, AZ
I ran out of time today to take pics - I'm going to run it through the wash tomorrow and vacuum it tomorrow then get some pics up.
I'd like to trade for a Cherokee XJ. I may be able to trade + some cash depending on what you have. Not interested in selling it outright, right now. I'm looking for an HO 6 cyl, AW4, 4 door, 4wd; A/C, PL, PW with a clean body. I'd prefer lower mileage, of course, but not totally necessary if it's in good shape. I'm more interested in getting an XJ with a good exterior and no rust. I'm more able to do mechanical work than body work.
I've had this truck for a few years and now I'm looking to get back into an XJ. My truck isn't the prettiest but it runs pretty good; however it does need some maintenance. I did drive it from TN to AZ over last winter with a load in the bed and cruised along the interstate with no issues. I'd rather put money into an XJ than into my MJ, so it's gotta go. Kraker and Tuffnutz have seen it in person, so they might have their own opinion of it :D
1988 LWB MJ with clear title
Passed emissions a while back and has current registration.
172,xxx miles
AW4
4.0L
PS
A/C
Bucket seats
Good:
Open cooling system modification
New radiator
New t-stat
New water pump
New transmission cooler (including temp gauge in dash)
New rear main seal with Fel-Pro oil pan gasket
New valve cover gasket
New oil filter adapter o-rings
Newer tires - lots of life left
AC and heat work
New catalytic converter
Little to no rust
Comes with MJ specific hitch (not attached)
Comes with extra MJ bumper (slightly bent)
Comes with extra fender flares (red, and not in best shape)
Comes with extra tail light
Totally sweet Wal-Mart speakers
1996 brake booster upgrade
Cluster swap from lights to gauges with original speedo so miles are accurate
Slider window
Smoker windows
5-90 Negative battery cable
Newer battery
Working spare tire winch
Newer brakes
Bad:
Body isn't in best shape.
Steering/suspension needs some maintenance
Rear bumper is bent
Small-ish crack in dashboard
Missing one B-pillar light
Driver seat has gangster lean
Fuel sender doesn't work properly
No headliner
Speedo needle has a slight waver
No b-pillar speakers
Slider window
Seats don't fold down anymore
Gauges act a bit wonky sometimes
Needs new positive battery cable
Passenger headlight is droopy - broken clip inside the housing
Door locks need a good lubing - they kind of catch. They always work, though.
Someone stole the radio out of the truck last night so it no longer has a radio. It wasn't anything special, but still typical of my kind of luck. No broken windows or pry marks on the doors - I left the doors unlocked last night. Good thing, because we found their 'breaking in' implement next to the truck.
how much do you want for it
When I bought it, I already had a 4WD XJ. This was less of a toy and more of a "I own a house so a truck is useful" kind of thing.
Shoot me a PM.
Well, I'll sell you mine for $1,999! It's under your $2k limit :D
I'm off this weekend if you are interested in taking a look at mine.
