gorilla_skater
- Glastonbury, Connecticut
For sale, Located in Glastonbury, CT
Summary:
RE Fixed LCA -$25
RE Fixed UCA - $25
RE Adj.track bar with Stock mount- $35
Rusty 4.5" coils - $40
ALL for $100
The Good: This is a complete 4.5" front suspension lift for an XJ. All you need are shocks and leaf springs to complete. Everything in working order except for the LCA bushings (frame mount)
The Bad:
Some Scrapes and Rust
You will definitely need new bushings on the LCAs, I had to sawzall the bolts because they were frozen/rusted in the sleeves in the bushing. $15 ea from RE and stock bushings also work
One of the Superflex Joints is a little loose and will need to be adjusted.
RE3700 - CONTROL ARM SF2 LOWER FIXED
Super-Flex lower fixed control arms for TJ Wranglers and XJ/MJ/ZJ (front only) Cherokees. All Super-Flex Control Arms feature our rebuildable spherical bearing assembly. This assembly features a large 2.25" polymer race that encapsulates a 1.75" hard plated steel bearing. A threaded steel insert allows adjustable preload and easy maintenance. The unit is greasable and extremely quiet due to the non-metallic races. This bearing allows extra flex for off-road prowess, yet does not sacrifice on-road handling or long term durability. $209.95
Length = 16"
http://www.rubiconexpress.com/SuspensionSystems/Product.aspx?part=RE3700
http://www.rubiconexpress.com/Jeep/XJ/Product.aspx?folder=XJCA&part=RE3701
RE3781 - Control Arm SR2 Upper Front Fixed
Super-Ride 2 fixed length front upper control arms for TJ/LJ Wranglers and XJ/MJ/ZJ Cherokees. $169.95
Length = 15 5/16
http://www.jeeperz-creeperz.com/control-upper-front-fixed-p-5370.html
RE1600 - TRACK BAR, FRONT XJ/MJ/ZJ/TJ
Correct alignment and handling problems on lifted vehicles with our front adjustable chromoly track bar. Easy installation works on vehicles with 3.5" - 4.5" of lift. Allows for more wheel travel than the stock unit and features a replaceable rod end for easier future maintenance. $164.95
http://www.rubiconexpress.com/SuspensionSystems/Product.aspx?part=RE1600
Coils - XJ 4.5" Front ? Rustys Offroad
150lb. spring rate. Powdercoated black for durability. - $100
http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Product_Code=RC-CS405-XJ&Category_Code=COILS
Summary:
RE Fixed LCA -$25
RE Fixed UCA - $25
ALL for $100
The Bad:
Length = 16"
Length = 15 5/16
