GhostDakota
- Phoenixville, PA | Bethany, DE
My manager is selling his '05 LJ Rubicon. Here are photos and info:
Mileage: 4,156 miles
VIN: 1J4FA64SX5P372167
For sale by: Private seller
Description
"This is a 4100 mile 2005 Jeep Wrangler Rubicon Unlimited. I am the original owner and shortly after acquiring it I started to modify it. From the specs below you can see that I have spared no expense in getting it ready to hit the trails. I unfortunately have not been able to use it for what it was built for, so it is in perfect shape. The only "off road" workout has been the obstacle course at the PA Jeeps show in York, PA. It has been garage kept since new and not shown in the pictures are the factory hardtop and full steel doors. I'm ready for a new project!
Payment: Cash or Certified Check
Thanks for your interest!"
Information about the Jeep:
2005 JEEP UNLIMITED RUBICON TJ
4.0L, 6-SPEED MANUAL TRANSMISSION, AC, SIRIUS SAT RADIO,
HARD AND SOFT TOPS, FULL STEEL DOORS
ADDED OEM ACCESSORIES:
MOPAR RB1 NAVIGATION SYSTEM, HALF STEEL DOORS
AXLES:
FRONT AXLE:
DYNATRAC PRO-ROCK D60, 5.38 GEARS, ARB AIR LOCKER,
HIGH-CLEAR STEERING OPTION, COMPETITION STEERING KNUCKLE HARDWARE,
CURRIE UPPER BUSHING TO JOHNNY JOINT CONVERSION KIT
WARN PREMIUM LOCKOUT HUBS
DYNATRAC STEERING STABILIZER
REAR AXLE:
SUSPENSION:
FRONT:
5-LINK WITH TRACK BAR = TERAFLEX PRO-LCG ARMS/BRACKETS,
FOX RACING 14" TRAVEL COIL OVERS,
POLY PERFORMANCE COIL-OVER BRACKET KIT WITH LIMITING STRAPS
OFFROAD ONLY SWAYLOC SWAYBAR
REAR:
4-LINK WITHOUT TRACK BAR = TERAFLEX PRO-LCG ARMS/BRACKETS,
FOX RACING 12" TRAVEL REMOTE RESERVOIR EMULSION SHOCKS,
NTH DEGREE SHOCK SHIFTERS, NTH DEGREE COIL SPRING RELOCATORS,
OLD MAN EMU 4" LIFT SPRINGS, TERAFLEX BUMP STOPS
BODY / ARMOR:
POISON SPYDER FRONT FLAT FENDERS WITH 3" FLARE (CUSTOM PAINTED)
POISON SPYDER REAR CRUSHER CORNERS WITH 3" FLARE (CUSTOM PAINTED) POISON SPYDER ROCKER KNOCKERS (CUSTOM PAINTED)
SKID PLATES:
KILBY STEERING BOX SKID PLATE
KILBY GAS TANK SKID PLATE
KILBY BODY CLAMZ BODY MOUNT SKID PLATES
NTH DEGREE OIL PAN SKID PLATE
TERAFLEX BELLY-UP SKID PLATE
BUMPERS:
REAR:
M.O.R.E. (MOUNTAIN OFFROAD) BUMPER / TIRE CARRIER (CUSTOM PAINTED)
FRONT:
CUSTOM USING BLUE TORCH FAB COMPONENTS (WINCH PLATE, GRILL HOOP KIT, D-RING MOUNTS)
EXHAUST:
CUSTOM CAT-BACK USING POLISHED STAINLESS STEEL MAGNAFLOW MUFFLER
OTHER ACCESSORIES:
WARN 9.5SI MOSFET WINCH
VIKING SYNTHETIC WINCHLINE WITH HOOK
VIKING OFFROAD ALUMINUM FAIRLEAD
CUSTOM LED TURN AND PARKING SIGNALS
OFFROAD ONLY LITE-DOT TAIL LIGHTS
M.O.R.E (MOUNTAIN OFFROAD) BOMB PROOF MOTOR MOUNTS
WRANGLER NW PRODUCTS DUAL BATTERY TRAY WITH ODYSSEY BATTERIES
WRANGLER NW PRODUCTS DUAL BATTERY IN CAB MANAGER KIT
ARB LARGE AIR COMPRESSOR (ORIGINAL VERSION)
AIRAID AIR INTAKE
DAYSTAR 1" POLYURATHANE BODY LIFT
WHEELS / TIRES:
17X9" MICKEY THOMPSON CLASSIC II 5X5.5 BOLT PATTERN
CHAMPION WHEEL BEADLOCKS
37X13.5R17 TOYO OPEN COUNTRY MT TIRES
PURCHASED BUT NOT YET INSTALLED:
NEW FRONT LOWER AXLE COIL-OVER MOUNTS
FOX RACING FRONT HYDRAULIC BUMP STOPS
POLY PERFORMANCE FRONT HYDRAULIC BUMP STOP BRACKET KIT
Description
AXLES:
FRONT AXLE:
REAR AXLE:
SUSPENSION:
FRONT:
REAR:
BODY / ARMOR:
SKID PLATES:
BUMPERS:
REAR:
FRONT:
EXHAUST:
OTHER ACCESSORIES:
AIRAID AIR INTAKE
WHEELS / TIRES:
