anthrax323
- San Antonio, TX
I have an NV242 transfer case (full- and part-time transfer case w/ 2.72:1 low range) pulled from a 2004 Jeep Grand Cherokee (WJ) that I ultimately opted not to use in my XJ due to the machine work needed to make it work for my application. Case is in excellent shape with only 2 issues:
This would be a great upgrade for anyone with a Grand Cherokee that has the terrible NV249 transfer case. Get yourself some real 4WD. All you'd need is the appropriate shifter bezel, which I could also get for you if desired - existing shift linkage should work fine.
If not buying locally, buyer pays freight.
- The slinger on the rear output shaft has been damaged due to my naiveté at the time of purchase - tried to remove it to verify the presence of speedometer gear splines on the mainshaft, but never followed through once I decided to keep my NP231. I can obtain and replace this free of charge prior to sale if desired.
- One bolt was removed for use on my NP231, as I lost one while rebuilding it in a cramped garage. Can also take care of this if desired.
