- Gassaway TN
I just took this off the trail rig and wiped it down. It has been used but is NOT bent or bowed. The passenger side TRE can be run as is but for a DD I might replace it. Driver side TRE is good and the drag link ends are good. $200.00. The reamed knuckles (D30) and pitman arm are included.
If you buy this, your knuckles and pitman arm will need to be reamed to accept the TRE's.
Will ship but on your dime.
http://www.jcroffroad.com/Merchant2/... egory_Code=S6
Thanks.
Thanks.
