1x1_Speed_Craig
- Grand Rapids, MI
In the course of rebuilding my daughter Mira's '93 XJ and my '05 LJ, I have accumulated WAY more parts than we need. This list is just the start...I have many more stored in my rafters, and will add to this list after sorting through them all. If you need '96-down XJ parts, ask me if you don't see something listed - there is a good chance I have it anyway.
Parts are located in Cedar Springs, Michigan (just north of Grand Rapids...zip 49319). If they're small parts, pick-up in NW Grand Rapids (Walker) is also an option. I prefer local pick-up, but will ship some of the smaller parts on your dime. If you need something shipped, please be respectful of my time, and try not to be a "tire kicker"...commit to the purchase. Much appreciated...my schedule is very busy.
I'll take payment by PayPal (craig.emenaker A+ gmail d0+ com), postal money order, or good ol' cash. I'm open to trades that would help with the build of my daughter Mira's XJ (build thread HERE).
Thanks,
Craig
Interior:
Engine Compartment:
Body:
Suspension:
Axles & Axle Parts:
Thanks,
Craig
Interior:
- 1995 XJ Steering Column: Complete with key. Includes good mechanically-actuated airbag. $40
- 1996 XJ Steering Column: Missing lock core and plastic "shroud" around lock core. Includes good mechanically-actuated airbag. $25
- 1996 XJ Dash/Gauges/Wiring: I planned on using this complete dash for Mira's XJ, but found another (later-model) option. $20
- 1996 XJ 4.0L Starter: Worked great, was keeping as a spare, but trying to free up space. $20
- Misc. interior trim pieces (just ask)
Engine Compartment:
- (3) 1996-down XJ electric cooling fans. 1-2 have cracked shrouds, but could be usable; the 3rd is in good condition. $20/all 3.
- 1996 Dual-Diaphragm Brake Booster. Excellent-working condition. I planned on using this, but will be using a 1999 model instead. $25
Body:
- 1996-down XJ/MJ Front Fender (driver): White, one VERY small dent; otherwise in nice condition. We planned on using this for Mira's XJ, but found a perfect one afterward. $15
- 1996-down XJ/MJ Front Fender (driver): Brownish, pulled from a late '80s MJ Pioneer. Pretty decent overall condition. $15
- 1996-down XJ/MJ Front Fender (passenger): Black, tweaked VERY slightly in the front. Easy repair, or use as-is on a trail rig. $10
- 1996-down XJ rear hatch: White, good overall condition. Includes rear defrost window and wiper motor. $20
- 1996-down XJ rear hatch: Red, decent condition. $15
- (All Years) XJ/MJ Hood: Red, a couple small blemishes, but good overall. $15
- (All Years) XJ/MJ Hood: Red, excellent condition, ZERO dents/dings/rust. $40
Suspension:
- TJ/LJ Rubicon Front Coil Springs: Super clean (still have the tags), no surface rust even. $35
- TJ/LJ OEM Rear Track Bar: 53K miles, zero rust, excellent condition. $15
- TJ/LJ OEM Front Sway Bar with Links: 53K miles, zero rust, excellent condition. $30
- TJ/LJ OEM Rear Sway Bar with Links: 53K miles, zero rust, excellent condition. $15
- XJ OEM Front Coil Springs: A couple sets to choose from. $5/pair.
Axles & Axle Parts:
- 1993 XJ HP Dana 30: Super clean, non-Michigan housing (most of it is still black paint), 3.07 gears, complete caliper-to-caliper including tie rod/drag link. Probably needs brake work. I planned on keeping this because of how clean it is, but $75
- TJ/XJ/MJ 2WD Front Axle. Missing 2WD specific bearings (only has spindles). Swap a set of 4WD knuckles/unit bearings/stub shafts on and use this for your Jeep rat rod. $30
- (2 sets) TJ/LJ Dana 30/Dana 44 knuckles. $25/pair
