FS: D30/8.25, gas tanks, misc. stuff
GoSlowGetStuck
Lafayette, IN
Leftover parts from the build. All parts are in Linden, Indiana. Anything here is deliverable to Redbird.
Dana 30, 3.55 gears, stock steering, control arms are probably seized and need cut off. $150
Chrysler 8.25, 3.55 gears, working limited slip. $150
Good clockspring 97+. $50
Good airbags 97+. Make offer.
Tilt steering column, intermediate shaft, wiper switch, key cylinder and key. From a 99. Make me an offer.
Stock plastic fuel tank with pump, 97+ top-loading returnless. $100
Aftermarket steel tank, ~30 gallon capacity I believe. Unknown manufacturer. Top-loading but return system, suitable for 95 or earlier model years. Not sure if a 97+ pump would drop in or not but I will investigate further. $200
I will put up pictures tonight, just making the thread now so I quit putting it off.
Whats the dimensions of the gas tank?....
Silly question, but may work for my CJ build...
It is intended as a replacement tank for an XJ and will bolt directly in, so it's not too far off on width and depth from a stock XJ tank. I'm sure it's at least a little taller though. I'll get you exact dimensions tonight.
I still have some of these things, and found some new stuff I would like to get rid of. Mostly I am trying to justify not throwing it in the trash.
Good clockspring 97+. $50? Make offer.
Stock plastic fuel tank with pump, 97+ top-loading returnless. $50
Aftermarket steel tank, ~30 gallon capacity I believe. Unknown manufacturer. Top-loading but return system, suitable for 95 or earlier model years. $100
Rubicon Express stuff:
top left 1x RE3798 small super flex races
top right 1x RE3797 large super flex races
bottom left 1x RM30215 large super flex housing
Other stuff:
bottom right 1x Omix-Ada 18280.08 leaf spring bushing
far right - 4 bar pin eliminators in varying conditions
Make me an offer on anything you want.
Tow bar. Uses a 2" ball. I think it said it's rated for 5000# but I will double check. I had some crazy plan to flat tow a Tercel whenever I had to drop my truck off at a shop. Make offer.
Time-delay brake controllers. As a person who tows a trailer I highly recommend a proportional controller, but as the person selling these brake controllers, they are awesome and you should own one. Make offer.
