GhostDakota
- Phoenixville, PA | Bethany, DE
I have a custom, heavy duty wiring harness for sale. It's got dual Hella relays, a fused positive, and is plug and play:
-1 negative wire to go to the battery
-1 positive (with the fuse) going to the battery.
-Factory harness plug closest to the battery plugs into the upgraded harness
-There are then 2 more plugs, one goes to each bulb in the headlight housings
Here's a photo of some of it:
Info on the connections here:
http://www.jeepforum.com/forum/f9/photos-writeup-dash-leds-upgraded-headlights-wiring-etc-685645/
This is a great upgrade for those who want to run higher wattage bulbs. It's also a great upgrade just for stock vehicles! You will notice a big output difference in your stock lights, and even more-so when running higher wattage bulbs. This has been a great setup for my Jeeps. I've run it on a YJ, XJ and TJ. I now have HID's which have their own wiring harness, so I have no need for this harness anymore. I purchased it for $95. I am looking to get $75 obo.
