pjanda1
- Boulder, CO
My XJ has about a 4.5" lift installed by a previous owner. The front shocks have a bar pin eliminator on the bottom, but they also have a bracket on the top that is like a bar pin eliminator, such that the front shocks are the same double eyelet style as the rear shocks. When fully extended, they measure 22" long. I think I need to replace them.
So, what sort of shock do I need?
If I stick with the existing brackets I assume that shocks normally spec'd for the rear of an XJ are a bit different, given how much more weight is on the front.
Or, should I remove the the top brackets a bad idea because they don't allow the 360 degree flex that front shocks normally have at the top?
Paul
Paul
