If i install an SYE will a front drive shaft work on the rear on my 99 xj after installing a RE 5.5 long arm?? heard it works but would like to hear it from the pro's here on naxja haha
There are 2 lenght driveshafts put in the front of the XJ. The driveshaft that is connected to a 231 t-case is different then the one connected to a 242 t-case. I can't remember which one is shorter but I do know that one of them will work. I'm running a 6" lift with SYE and have a front driveshaft out back that I got at the pick-a-part. You need to take some measurements to figure out what length you need and then go look at the 2 kinds and go from there. I will be heading to the pick-a-part this week to get another spare driveshaft and I will keep an eye out for one for you. I will also figure out which is the longer option.
It seems to change every time I go. The last one I picked up was $25 but that was on a 1/2 off day then I bought another for $40 on a regular day. Someone on this site said they paid $60 at that same location. I'm not sure the reason for the fluctuation but the cost is somewhere in the $25-60 range. They often do 1/2 off on rainy days so I'm heading down this week in the rain and crossing my fingers on 1/2 off. PM me your cell number. If I find one I will call you to see if you want me to grab it for you.
all i want to do really is use it for a while till i get enough money to get one from tom woods. I ordered the sye from AA and they sent it to me now after i get it installed they are sending me a TW drive shaft once i get the measurements, lift and sye are installed. so i would not mind running that front at all because then eventually it will be a spare stored in the jeep or garage.
Thanks for the info and the heads up though
I wouldn't fully agree with that. I run 35's and have run most trails in JV, the Rubicon, Moab, and numerous other difficult trails with stock front driveshafts out back with little issues. I have bent a few on rocks but never snapped one. It's also nice to be able to hit the junkyard for a spare or replacement for cheap.
Maybe you don't wheel as hard as cracker does. Most of the trails in JV? There are like 50, I hope you have a big stack of those front drivelines handy.
I would never trust a front driveline in the rear either. I've been known to use the throttle here and there, and need to have absolute faith in my driveline.
