IntrepidXJ
NAXJA Member #647
- Grand Junction, CO
ZacSquatch said:Anybody know if they give a discount? If so I need to call em back.
don't believe so.
but if you order thru jeepinoutfitters, you get 5% off
steveareno said:I have Detours, they are a full boxed square-tube attached to front and rear spring perch, then plug welded to unibody. It is like adding a frame, not just a stiffner. And, then mine came with rock rail sliders as part o the unit, so stiffner and rails are all tied together.
JonnyK said:Obviously it's going to be cheaper if you have the time, tools, and skill to fabricate something. The Detours stiffeners/sliders seemed like a nice integrated solution to me without having to worry about what fits with what (and they're local for me). So that's what I went with and they work great so far. No complaints or second thoughts.
Stop driving into the rocks:laugh3:IntrepidXJ said:now....do they prevent you from smashing the bottom of your framerails in? i've had that problem
mikeNtucson said:I was going to get a set, but I was told by fab shop that they are best for sand dune, that the body of the xj is designed to flex. That he had done 2 jeeps and both developed a crack in trans tunel. One had a crack 14" starting at hole for shifter going back.
