95 xj
I'm doing a wiring upgrade for the foglights, heavy gauge wire, relay and so on. In the past when I have done this I've always used the existing positive lead that would normaly go to the lamp as my signal wire for terminal 86 on the new relay. Can't do that this time because the circuit is screwed, when it isn't dead it's blowing fuses. I just want to isolate the old circuit and forget it.
So, the question is, what do I use as a signal for terminal 86 on the new relay?
Thanks,
Chris
Thanks,
Chris
