RoyalXJ
- West Deptford, NJ
That's like saying my only concern with mech fan is what happens when you lose a belt
i dont know about you guys but i always have spare belt in my jeep
GoJeep, IINM, lists some CFM values on his site- IIRC he did some simple tests to come up with them. It's surely around here somewhere.
I removed the bump in the radiator hold down for easier mounting.
The fans are now done and mounted. I still need to do some testing.
I was of the opinion that that was what the GEN light was for, though it'd be trivial to build one. I keep a VERY close eye on my gauges, check them every minute or two, because I've had oil pressure and coolant temp issues on the MJ in the last few months (both fixed seemingly.)Me, I'm anal on the gauges, always checking them.
How about a low-voltage alarm/warning light?
X2. No belt means no water pump and no mechanical fan AND after a while no e-fan either, not that it matters with no water pump.No belt, no water pump. Things get real hot real quick.
Likewise. If I replace my belt, the old one goes under the back seat with the jumper cables.i dont know about you guys but i always have spare belt in my jeep
Did you ditch your A/C also? Thats a pretty short belt.I used a K060837 belt on my '89 when I installed a Taurus fan.
Time for a final update and some more pictures. Everything is still working great. I set the fans to turn on at 210°F to let the engine run a little hotter before it would get in the 180° range which was a little low. With the fans set at the higher temperature it now runs in the upper 190°'s and a maximum of 210°.
A side view showing the clearance
Had a small issue with low voltage at idle installed a Powermaster 47902 140A alternator
