Do you have issues with the bottle mounted sideways?
Markos I'm not raggin on you here just relaying my reasoning.
Let me also say I carry a Co2 tank so this is not meant to say they are bad just informing the masses of the gotchas.
I worked for years in a welding supply house and trust me you don't want to be around a Co2 tank if its laying on its side and the safety on the valve pops, you get a stream of liquid Co2 instead of gas. You are begging for instant frostbite not to mention you have a near instant snow and fog storm in your jeep. Think of a Co2 Fire extinguisher set off in the back of your jeep with no way to shut it off.
Most people think that safeties only pop when the tank is over pressurized and that is their true purpose. However I think we can all agree that there is metal fatigue and a safety bursting disc is made of very very thin metal. Combine this with the fact that Co2 has one of the widest pressure swings in relation to temperature of any gas you have the makings of a popped disc over time. In other words the pressure rises quickly as the temperature rises and the reverse is also true.
On a typical Colorado day it would not be uncommon for a tank in a enclosed jeep to vary several hundred pounds in pressure from morning to night. Over time this creates fatigue on the safety disc and can lead failure at a lower then designed pressure without warning. We routinely had safeties pop while the filled tanks were sitting in stock out on a open dock from just this reason. Age of the safety disc obviously has a roll in this since the fatigue is cumulative. You are probably at more risk if you use a tank that is swapped out for another one every time its empty and you have no idea of its history then if you own your tank. I would insist the disc be replaced every time the tank is hydrotested.
Another hazard that no one ever seems to mention is suffocation if this happens in a enclosed space. This is true regardless of the mounting position but if its dumping liquid the process is a lot quicker.
A 20# tank equals about 2.3 gallons of Co2 which makes about 170 cubic feet of gas at 70 degrees F. It does not take long to dump a 20# tank when the safety pops...I mean thats its job to dump the pressure. Also keep in mind it does not have to displace all of the oxygen just enough to lower the level to a point you pass out. I am not sure of the cabin size on a TJ but I am willing to bet it is less then 80 cubic foot so a 20# tank would displace the contents of the cab twice.
Granted this is not a big deal if you are just tooling down the trail and you can open the door but if you are in a rollover and knocked out or trapped and cant open a door you stand a good chance of sleeping for a very very long time in a nice metal box under a well maintained lawn.
Will anything happen if you mount it on its side probably not but I am not willing to risk it to save $30 bucks on a proper mount. I mount my tank in a DOT rated fire extinguisher bracket in a upright position and drive with doors off or the windows down regardless of weather. Maybe I'm paranoid but I think I am just being cautious because I have seen one of these blow a safety first hand.
ETA: I also only carry the tank when on the trail not in everyday driving.
Thanks, that's pretty good. Cheapest I found was on ebay for $78 + shipping. It was a nice 10# aluminum one though.
The yellow tank looks more like a regular air tank, possibly a Scott or something similar, from the fire service where it may have used as an SCBA.
