- Rainy side of Washington
My rear brake line is really close to taut with my 2" OME lift even when sitting level - the 1995 YJ rear brake line I got from AutoZone cost me $15.99. Two front brake lines will cost ten to fifteen bucks each also, figure a total of 45 dollars. I probably could get away with using the stock brake line for a while but I've had two brake lines pop on me already (one luckily while I was sitting in the driveway with my foot on the pedal) and so I'm just a little paranoid about them now.i went 2" w/o a problem, if your still using stock LCA's the LCA's will hit before your brake lines fully extend, and if your still worried about them coming up short, you could simply unbolt them and relocate them lower.
i didnt need longer brake lines until i put on my 4.5" coils and aftermarket LCA's, im still running 3" longer shocks and when i just unbolted the hoses from the fenderwell and fulled extended, they didnt get stretched out like i had expected them to, the shocks topped out first.
im not saying to not get new brake lines, all im saying is if moneys tight and you cant afford the extra 100 bucks on brake lines then you can simply relocate your stock lines lower and more forward.
Note - also be careful on your front bleeder valves if you do replace the brake lines, the fronts require a 3/8 wrench while the rears require an 8mm wrench, the fronts are usually in really tight so use a 6-point socket to loosen them before using a wrench to actually bleed, they are far too easy to round off.
