GSequoia
Body
1996 Jeep Cherokee Country
Four doors, child safety locks equipped on rear doors
Black with peeling clear coat
Small dent in passenger quarter panel
Safety
Shoulder belts for outboard passengers front and rear, lap belt for center rear passenger
Driver air bag
Intrusion prevention bars in side doors
Power and drive train
Jeep 4.0 High Output PowerTech I-6 Engine
Aisin Warner AW4 four speed automatic transmission
New Venture 242 Selec-Trac Transfer Case. 2.72:1 low gear with full time range
Transfer case and rear transmission attachment point lowered 1" using RubiconExpress transfer case drop, transfer case skid mount lowered 1" as well using custom spacer.
High pinion Dana 30 front axle with open carrier and 3.55:1 gears
Low pinion Dana 35 rear axle with Trak-Lok clutch based limited slip, it probably works
OEM Jeep driveshafts with Spicer U-Joints
OEM Jeep axle shafts with Spicer 279x wheel U-Joints in the front
Suspension and Steering
Factory Jeep Quadra-Link front suspension linkages, includes two lower control arms, two upper control arms, and one track bar
Power steering with factory Jeep components including drag link and tie rod,
RubiconExpress budget boost; includes 2" front coil spacers and short Add-A-Leaf insert for rear leaf packs
Braking
Factory four wheel Antilock Braking System
Dual diaphragm power booster
Disc front brakes, 11", single piston floating caliper design
Drum rear brakes, 9" x 2.5", one wheel cylinder per side
Mechanical parking brake actuating rear drums
Wheels and Tires
Jeep Grizzly wheels
BF Goodrich All Terrain KO tires, 31" x 10.50" x 15"
Vehicle Protection
Mopar skid plate group; includes front of engine, transfer case, and fuel tank skid plates
OEM front tow hook brackets with chrome clad hooks
Towing
Factory Class III receiver rated for 5,000 lbs weight distributed towing
RV style seven pin trailer wiring harness; includes ground, running lights, brake lights/turn signals, +12VDC, brake controller, and backup lamps
Luggage Capcity
Factory full length roof rack with seized cross bar buttons
Load hooks in floor of cargo area
Lighting
AutoPal EU spec headlamps with 35/100 bulbs
Hella 500FF fog pattern lamps
EU spec front marker lamps (amber in color as opposed to clear US style)
EU spec tail lamps
LED accent lights under rear bumper for extra backup lamp power
Interior
Genuine torn leather seating surfaces
Color matched all-weather floor mats
Overhead console with compass and thermometer
Audio
Alpine CDA-9856 with iPod adaptor
5.25" speakers
Communications
CB Antenna bracket on left rear corner
Cobra 75WXST
NMO mount for 2-meter radio on center of roof
Yaesu FT-1900 2-meter radio
Navigation
Jeniko Laptop computer mount
Dell Latitude D505 with DeLorme Topo USA and Street Atlas USA using DeLorme EarthMate GPS
Various maps located between center console, door map pockets, and floor of passenger area
Driver with a decent sense of direction
Well a bit of a brief example but that's all I can think of at the moment, now for two photos.
Near Sherman Pass, Sequoia National Forest, CA
May 28, 2011
Near Parker Meadow, Sequoia National Forest, CA
May 29, 2011
