blackdoutxj
- Temecula,CA
does anyone have directions on how to change em....
cstilesiscool said:yeah take off the fan shroud and it makes it an easy task. don't loosen or take off the belt. leverage really is your friend on this task. it took me 1/2 hour tops to do.
cstilesiscool said:i guess i should of pointed out that since the fan shroud is plastic, i went ahead and cut the shroud right down the middle in half on the bottom part since it's held in by a slot on each side. so all i have to do is take off the tops bolts and slide it out from the top with a little maneuvering. when i made my statement i wasn't thinking that i had done that. makes it a ton easier and it hasn't hurt anything doing it. it fastens right back into place with no problems and i've been running it like that for over a year.
blackdoutxj said:ok sop far i have 1 bolt off and it keeps spinnin on me... where do i put the screw driver to make it stp spinnin
blackdoutxj said:thats the thing the pulley is spinnin not the belt...
