ROCKWGN
- San Diego, CA
Someone can bone in here if I am wrong. When the engine is cold the fan should spin very easy on the fan clutch, as the engine warms up it should start stiffing up. Bring the car up to operating temperature, turn off the engine, do not stick anything in the fan while its on, not a good idea. Wjth the the engine warm, and off, the fan should not spin easy, it should feel locked up. If it spins say one full turn, the clutch is bad. I had the same problem a week ago, the problem way my radiator was 75% plugged. I only had 30,000 miles on it. Did the repair place give you a NEW radiator, or a core? I was running in the 220-240F range. I had the radiator rodded and put in a 185* thermostat. It now runs below the 210* and I can crank the AC, its great... Good Luck
Sean
Sean
