much2real
- In the pines, in the pines
old_man said:High Pinion rear?????? Didn't think there was any such animal.
x2
there's not stock. it's custom.old_man said:High Pinion rear?????? Didn't think there was any such animal.
rsalemi said:Use synthetic and add the extra quart. we had the same problem (looseing pinion bearings) in a 9' Ford in the dragster - probably because the acceleration moves the oil to the back of the case, uncovering the pinion bearing. i beleive synthetic is more resistant to foaming - and I know it has better "cling" providing lubricant even when uncovered.
explorer said:I forgot to mention the link between synthetic and foaming in my other post.
During my tenure with Jeep, they were always updating this or that, one of the things being various RTV formulations. We had 3-4 different types at any given time based on the application. Anyways, at one point, there ws an incompatibility between a certain RTV and the factory fill of 75-140 synthetic that caused excessive foaming. I believe it was with the orange RTV that the original assy. was done with(don't hold me to that though). The factory recommended RTV from that point on and still I believe is a grey RTV. This issue was also believed to be partly to blame for the very common problem of brg. failure.
any idea how much it dropped before it stopped puking?Capt. Nemo said:I run a HP cover on my standard rear. When I originally filled it up, I filled it until the gear oil ran out of the fill hole. This is a whole lot of oil, especially since the oil also lubes the outter axle bearings. Well, for about a week after I filled it up, it puked oil out of the breather tube every time I drove it. It eventually it stopped, but it was alot of oil. I'm swapping out the axles this weekend, so I'll be re-filling the axle to an acceptable level.
All that to say that I know I overfilled the axle, and I've had no problems other than oil puking everywhere for a few days.
BrettM said:any idea how much it dropped before it stopped puking?
Kejtar said:Ummm neither. Use the HP cover and don't fill till it flows out, but add the right amount and then a little bit more to account for the angle change.
Kejtar said:Umm that sounds like BS as I just drained synthetic Valvoline from a diff that was sealed with orange rtv. Unless that reaction was with specific brand of synth oil (plus another question is which vehicle came with synth 75-140 in the axle from factory?)
Hmmm that is interesting though. I wonder if it has to do with different RTV and or Oil used by the dealership. Or maybe I don't see that beacuse I ussually don't drive my jeep right after diff fluid change.explorer said:I'm just passing on info that we were given. And starting around 96 or so, all axles were factory filled with the synthetic. Another thing I forgot to mention, the reaction was with uncured RTV meaning the problem only existed with a fresh service of the diff oil. I'm not just making this stuff up.
