2001XJ
- Canton, MI
Anyone run into issues when upgrading their rear brake/park/turn, front park/turn (3157s) with LEDs and their front side marker (168s) with LEDS.....basically all running lights with LEDs and not get them to work properly? I recently did this and when trying to use trun signals I get this weird humming/buzzing noise and they don't work. The signal indiactor on the intrument cluster shows a solid green arrow instead of blinking. Also, when turning them on either to have them on as parking lights or when using my headlights, the right side turn signal indicator stays on the whole time. When I try to use my hazards though, they all work.
Obviously, this is a voltage issue. I am assuming the LEDs are pulling lower voltage "as a whole" and it's seeing the load as a burned out light. Anyone use the flashers or load stabilizers from autolumination? Will this cure the problem?
Suggestions on how to recitfy this?
TIA
TIA
