MogifiedXJ
- Tellico, TN
I wonder where you would find those aluminum ramps with the punched holes in them for driving over stuff?
2xtreme said:Michael
PS. Most expedition racks use gutter mounted supports. Usually with 4 or 6 points of attachment (depending on size and weight).
cracker said:Unfortuatley the two piece XJ raingutter design won't hold up
2xtreme said:Not sure what you mean by two piece design?
Most external raingutters that I am aware of are the joint for the lower body structure and roof. A VERY strong part of many vehicles. Is there something different on an XJ that I am not aware of that would make it different than any other vehicle?
There is no reason that a properly attached rain gutter style mount for a expedition rack could not support 2-3 hundred pounds. Anything more than that weight and I think there are other areas of concern on an XJ personally.
Been there, done that, now I like my XJ.Root Moose said:I'll take some images (PM to follow).
When I was looking at a vehicle to build this is one reason why I discounted the FJ60 and FJ80 at the time - gas mileage. In retrospect...
Mind you, a FJ55/60/62 with "modern" drivetrain (SBC, 700R4, NV case) should get pretty good mileage compared to stock. We got the FJ60 and FJ62 up here with the diesel - both 4 cyl and 6 cylinder variants IIRC. I dunno if a 55 would be a good expedition truck given the age. Depends on what you are prepared to put up with I guess.
Nevada City Sparky said:I swear, when I started grinding on the body, I could see "Miller High Life" labels coming though the steel. Not really, but it was mighty spotty with different colors of steel.
Root Moose said:LOL
I second what cracker is saying about the rain gutters.
For thoese that haven't noticed this... go to your XJ and grab the rain gutter at the top of the A pillar and pull. Don't pull to hard though or you'll pull it of all the way back to the D pillar.
John B said:But isnt that just a trim piece? How does that affect structural rigidity if pulled off? The gutter is still spot welded together making it a solid mounting point.
If it is different than say an FJ80 please enlighten me as i am building an Expedition XJ and am currently using a gutter mounted rack.
cracker said:It is a Trim piece of the vehicle that doubles as structural to the rain gutter ONLY. Without that piece the rain gutter clamps have nothing to attach to. As far as structural for the whole XJ, it is not.
Mine broke off within two months of use. It was/is a Yakima rack with 6 raingutter feet (3 load bars). After that 'trim' piece broke the rack would slide forward and pop off.
hadfield4wd said:I'll look over the weekend. My wife has them catalogued by date in the attic.
Matt
Just do a disc swap?Add a full float option to the rear axle.
