Vanimal
- escondido, ca
my trans tunnel seems to get stupid hot on long drives. is this normal for these things? almost seems like a fire hazzard. my phone was sitting in the little tray under the ebrake handle and it shut down due to the heat, and would burn my face if i tried to use it. the heat coming off of it makes it hard to drive, especially in shorts.
my temp gauge stopped working recently, but it typically never overheated and the electric fan hardly ever turns on when wheeling. i'm going to try and fix the temp gauge, but i dont think it's overheating.
a few facts, some may be related, some might not.
91 xj 4.0 ax15 231
zj fan clutch
newer radiator and water pump. coolant looks good
220k miles
original cat followed by a thrush turbo muffler and a turndown pipe
transfer case may be a little noisy, it seems to have a whiney noise and some marbley noises when i come to a stop. wondering if the heat is coming from that? works fine otherwise. the jeep used to have a disconnect axle, so the noise wasnt there before because the driveshaft didnt spin when driving. now it does, which makes me think this is the source of the new whining noise.
i do still have my carpet and center console. might try hood vents, but i just find it hard to believe they'd let a vehicle this new go out the door of the factory if they all get this hot.
91 xj 4.0 ax15 231
zj fan clutch
220k miles
