1. Maybe I can add a little info to the knowledge base. Transmission problems began with an overheating event on a very hot day. One of the problems was that the darn thing wanted to grab a different gear, out of the blue, for a split second and then it would go back to where it was supposed to be based on vehicle speed and gearshift position. It felt like a loose connection - more prone to happening when accelerating and/or going around a curve. Adjusted TV cable and changed out TPS and solenoids. Then changed out the TCU, which I gave no chance of fixing the problem, and that did, indeed, fix the problem. So a bad TCU can mimick what seems like a loose wire/bad connection.
2. Referencing my post no 173 and Kastein's response in no 175, I did indeed change the VSS (obviously wasted money) and, now that I have a different TCU, I still do not have natural TC lockup from the TCU.
a. Can the OSS, which has not been changed out, affect lockup? Transmission seems to shift normal and I assume the OSS has some impact on that. Accordingly, the OSS seems to be working okay?
b. Again, the cruise control works fine so I've always assumed the break light switch was not the problem. Is there more to consider in that area?
c. There are no classic warning signs from the NSS. There isn't even a hint of a "connection" problem when starting.
d. I know that down stream from the TCU everything is fine because I've wired around the TCU for manual activation of solenoid 3 - works every time.
Regarding the fix of the final problem (TC lockup) any ideas / suggestions are welcome.
