I have an 89 but it should be about the same. When I pulled it I used the last head bolt and the top hole for the ac bracket, no valve cover. When I put it back in no valve cover, intake or exhaust used the same ac hole and the last top hole for the exhaust. I pulled the transmission and transfer case at the same time I don't know if this will help you or not.
