JNickel101 said:
Yes, thousands of people must be wrong....
There are probably twice that many that bought 'Slick-50' too.
Three things to start, shop vac with a crevice tool, selection of plastic scrapers, pan big enough to put the cover in.
Remove cover, turn on shop vac and keep in one hand, pick up scraper in other, work them together, don't miss ANY pieces of sludge, let the vac suck them up as soon as you break them free with the scraper. Make sure you have a good light illuminating the work area.
Submerge the cover in the pan with gas, kerosene, etc, let it soak then clean it out.
Reassemble, change oil with cheap stuff, now you can add some engine cleaner like seafoam or whatever, run it then change it again, for this I would use cheap Fram filters. Once the cleaner starts working it will soak into the stuff and start to break it down. When you change the oil that stuff is still soaked into the build up so it will continue working for a while so watch your dipstick, as soon as it gets to where it's hard to read the writing change the filter. Around about the second one change the oil and put your normal stuff in with a good filter and go from there.
The other way is to start using your own mix of regular oil and synthetic, don't bother with buying the mix, we have no idea of the mix percentage, mix your own, 3 quarts of regular, 3 quarts of synthetic. The synthetic will also soak in to the sludge and start removing it, it will take longer so your oil will get dirty faster and require more filter changes but it will work, also keep an eye on the seals for any leaks.
