boomer1
- Northglenn, Co
Hey everyone - thanks for looking
I've got a 1988 - 4.0 MJ that I've restoring.
Picked it up in 2009 with 291734 miles on it. According to the seller, his dad had rebuilt the motor at one time, but he didn't know how long ago, or how many miles ago. I can say that it runs like a scared rabbit, smooth, no leaks.
In 2009 when I ran it through emissions these were the numbers:
HC limit 3.0 reading 1.0
CO Limit 25.0 reading 9.35
CO2 reading 298.179
NOx limit 5.0 reading 1.9
Passed with no problems
In 2010 when I ran it through emissions 297186 miles on it:
HC limit 3.0 reading 1.35
CO limit 25.0 reading 24.97
CO2 reading 394.422
NOx limit 5.0 reading 1.27
As you can see it barely passed with the high CO limit. No changes to the engine between the years, but it does seem to idle a little high when it's cold, I guess it might be the TPS, but don't know.
I'm thinking that maybe the cat and O2 sensor might need to be replaced. Would that be a reason for the CO readings being so high?
I don't if I want to see if it passes, or suck it up and replace the exhaust system. The exhaust pipes and the muffler are pretty rusted it out, so it would probably be a good idea to replace the entire thing from the exhaust manifold back.
In your expert opinion, what do you think?
Thanks in advance for any suggestions
CO2 reading 298.179
CO2 reading 394.422
