i believe the evaporitive system is the sysytem that recycles evaporized fuel. I would check the vac lines that run from the tank to the engine bay aswell as the charcoal canister and its lines.
There'a a pump or something on the firewall near where the AC pipes go in. It has a cable and a couple of hoses going to it. Normally it should pulsate and you should be able to feel it. It's for venting the fuel tank. On my 99 it even has a port with a small tag telling you the pressure reading. My 96 also had one but I don't remember the test port.
